Ladies Rolex Precision Cal.1401 18ct c1971
PS: This watch is listed on behalf of our trusted users at valueyourwatch.com. If you have any questions about the seller, do not hesitate to contact us at info@valueyourwatch.com. Our sellers are verified sellers with a strong reputation.
The asking Price will be $5,900 payment chosen by the seller. In general, you can pay by Credit Card, Wire, PayPal, Cash or others.
For more questions Tel. +447515949250 email: alan@vintagegoldwatches.com
Connect with me on instagram
100% Genuine & All Original
Fully Serviced, Inspected and Guaranteed
A Delightful Well Cared For, Immaculate Example
Case Size 20mm, Including the Original Signed Crown
Wonderful Rare 18ct Yellow Gold Bark Rolex Case and Bracelet
Original, Unrestored and Untouched Silver Dial With Original ‘Lance’ Hands
High Grade Rolex Cal.1401, 18 Jewels, Hand-Wound Movement
All Absolutely Immaculate and Simply Amazing Condition
High Quality Hardwood Presentation Box Included
VGWL Lifetime Authenticity Guarantee Included
VGWL 12 Months’ Written Warranty Included*
Free Worldwide FedEx Delivery
Free UK Special Delivery
Description
The watch we have here is an absolutely amazing example of the ladies Rolex Precision **** watch in 18ct yellow gold from c1971. This watch is complete with its original integral bark bracelet, also in 18ct gold and made in the UK for Rolex by the famous watch case and jewellery maker, Global Watch Maker. The condition of the bracelet, watch case and movement is superb, indicating this watch has only ever seen very light occasional and careful use.
The Dial
The original, unrestored and untouched silver dial with applied ‘baton’ hour indices is, as can be seen in the close-up photographs, in superb condition. The dial is complete with its original ‘Lancette’ style hands which are also tip-top, especially considering the age of the watch.
The dial is framed by a beautiful crystal effect bezel insert, which catches the light wonderfully. It is crowned with the usual Rolex ‘Coronet’ at 12 and is signed ‘Rolex’ with ‘Precision’ below.
At 20mm diameter, including the crown, this is quite a small watch in comparison with most others, however, the dial is quite easy to read, even at arm’s length.
As mentioned above, the dial is original and unrestored and has been left untouched by our restoration team due to its superb condition. Usually, we restore the dials of the watches we sell, however we decided in this case to leave it alone, due to its unusually good condition and to retain its originality and charm for those who prefer this. It also helps to contrast with almost all of the other watch dials you see on our website, which have been restored. The hands, likewise, have also been left in their original untouched condition.
Please note, studio lights, professional-grade digital cameras, and macro lenses can be very unkind to an unrestored vintage watch dial. Also the dial here measures less than 1.25 inches across, so the image you’re seeing may be between 5 – 25 times larger than the watch itself. Therefore please keep in mind you are seeing many tiny flaws which cannot be seen, or will be very hard to see with the naked eye, even under close examination. Suffice to say, on the wrist, in natural light, this dial looks much better and carries a great deal more charm than the photographs portray.
The Movement
The high grade Calibre 1401, 18 jewel hand-wound movement is in incredibly clean and sparkling condition and has just been fully overhauled and serviced by our expert vintage Rolex specialist watchmaker.
Rolex went to considerable lengths and expense to ensure its 13.75mm diameter, Cal.1401 series movements performed equally as well as its larger gents Precision movements – and they succeeded! These are indeed high precision movements and the example here is running perfectly, having been calibrated to run consistently within plus or minus 9 seconds per day! This is truly outstanding for any mechanical watch and it is no exaggeration – we have checked the test results on our electronic watch timegrapher. This movement also has an excellent power reserve of 44 hours when fully wound.
The movement is signed Rolex, ‘Swiss’ and ’18 Rubies’ (Jewels) and it is marked with the Calibre number 1401. This particular movement is in beautiful condition and with regular servicing, say every 3 to 4 years, we would fully expect this watch to continue to run very happily for another 50+ years! We are therefore totally confident in offering this watch with our 12 months written warranty*.
*Please note – our 12 months’ warranty is only applicable if the list price is paid.
The Case
The 18ct yellow gold case measures 20mm in diameter, including the correctly signed crown. Please note, the winding crown stem is slightly extended but remains hidden by the bracelet. The watch is easily wound by running one’s finger along the back of the crown. The hands are then set by pulling the crown from the underside of the bracelet
On the inside of the case-back, the markings are all correct and signed ‘Montres Rolex S.A’, ‘Geneva Switzerland’ along with the correct 18ct hallmarks and the model reference number 2606.
The case is of a very solid two-piece design with an integral bezel. This design improves water and dust resistance. The press-fit case-back clicks into place with a firm and satisfying ‘pop’, indicating it is a nice tight fit. The case-back is of full thickness and has never been inscribed.
This watch has exceptionally well cared for and has simply required a clean, thorough inspection, then a gentle hand-polish to bring it back to its current ‘like new’ condition with no scratches, dings or other forms of damage visible to the naked eye.
Please note – our standard advice applies: Vintage watches should be kept clean and dry at all times.
The Bracelet
The original, integral Rolex signed bracelet is in matching solid 18ct yellow gold and has a wonderful bark effect. The bracelet is in fantastic condition, showing no significant signs of wear or damage visible to the naked eye. The bracelet is, as expected, superbly made and quite weighty and substantial. It is also in wonderful condition. While the links do not stretch, they are just flexible enough to hug the wrist beautifully with no gaps or unevenness in any of the links.
The bracelet remains at its original standard 17.8cm length, which means the watch and bracelet are a perfect fit for a lady with a wrist size/circumference of 17.8 centimetres. The original Rolex signed clasp and lock is superbly designed with a safety catch which securely locks, making the watch secure on the wrist. This means it is impossible for the clasp to become accidentally undone and for the watch to become loose on the wrist.
Please note – the catch is not adjustable, meaning this watch will not fit a larger wrist. However, it could be tailored to fit a smaller wrist. If upon purchasing this watch, this becomes necessary, we will be pleased to arrange this for you for a nominal fee.
Please call or message us to discuss this, or if you have any queries about the bracelet or any other aspect of the watch.
Box and Papers
Although there are no original papers with this watch, the reference numbers, markings, signatures and hallmarks are all correct, dating this watch to c1971.
Detailed particulars will be included with our purchase receipt for your interest and security. A separate insurance valuation for the replacement value of this watch will be provided at the time of sale along with our unique ‘Lifetime Authenticity Guarantee’ which states: “If this watch proves to be anything less than 100% genuine, authentic and original, a full refund will be given at any time”.
The high quality hardwood presentation box shown in the photographs is included in the sale.
If you would like to pay by bank transfer we will be pleased to assist you with this and pass on a 3% saving to you. Paying by bank transfer for a 3% saving will not affect your 12 months warranty. Similarly, if you wish to pay by International SWIFT or Bank Wire Transfer we will provide you with our BIC / Swift number and our IBAN number.
Please check the import duties and any taxes your government may apply, these are different for each country and unfortunately out of our control.
We understand there may be some ‘loopholes’ that may help you avoid these charges, however attempting to use these could impact our ongoing ability to serve our growing international customer base.
For those that happen to visit the UK on occasion we are of course more than happy to store your watch until we can meet you in our offices in Kensington, London and deliver your watch directly to you there.
As with all our watches, this watch will be sold under our 14 days no quibble sale or return policy.
In Conclusion
This is a superb, highly collectable and totally usable vintage watch from horology’s most famous name, which will provide an excellent financial investment as well as be something to treasure and enjoy! It will make the perfect gift as well as a practical, accurate and reliable timepiece to use on a regular basis, as you so wish.
A word on our prices – We always try our hardest to acquire the very highest quality watches we can find, before restoring them to the highest possible standards. We then offer these at the fairest prices we can, taking into account our pre and post-sales care and service. This approach means we will never be the cheapest, but nor will we be the most expensive. Indeed there are some well-known stores in West London which are highly successful charging between two to three times the price you see here. We, therefore, consider our prices to be fair, given the quality of watches we have to offer.
Please note, we also welcome part exchanges. If you have a watch or a small collection for sale, please contact us as we will be happy to discuss this.
We will also be happy to Service your watch, Repair your watch or Restore your watch, all at ‘sensible’ prices. Please see here.
If you have any questions please call us on 020 7727 7095 or if calling from overseas on +44 207 727 7095.
Please take a look at our other fine vintage gold watches.
Thank you.
More Pictures: Value Your Watch
FS: Ladies Rolex Precision Cal.1401 18ct c1971
- ValueYourWatch.com
- Brand Rep
- Has thanked: 8 times
- Been thanked: 1913 times
Honza Hroch / info@valueyourwatch.com / No Sellers Fees, No Buyers Fees
Buy and Sell Luxury Watches at Value Your Watch Marketplace
- Brand Rep
Re: FS: Ladies Rolex Precision Cal.1401 18ct c1971
UP
