Just in time for the Holidays, MAS Watch out of Australia, has launched an updated Kickstarter campaign for their Irukandji automatic diver in a limited run of "seriously fresh colours."
*NOTE* This is a short, six day campaign in order to allow backers to get the Irukandji before the holidays.
Additionally, there are only 10 watches in each of the new colors available via Kickstarter. The remaining stock can be ordered direct from MAS.
Kickstarter pricing is around $292
Regular price is about $347
Estimated delivery is December 2020
There are five new colors available - Tentacle Purple, Sea Green, Starfish Orange, Seastorm Red, and Tropical Yellow.
Original colorways of Stinger Pink, Reef Blue, and Deadly Black are also included again for the same Kickstarter pricing.
Once there are 10 backers, they will include a FREE GIFT with every Irukandji; a 'Tiny Time Tool' portable strap/bracelet accessory:
- 316L, marine grade stainless steel case (brushed)
- Case is 42mm at the wrist and 39.5mm at the bezel, lug to lug is 46mm
- Drilled lugs. Lug width is 20mm
- Domed sapphire crystal with anti-reflective (AR) coating on the underside
- Height is 13.13mm from caseback to bezel, or a 15mm total including nearly 2mm of glorious dome.
- Unidirectional bezel, with lumed ceramic insert
- Signed, screw-down crown (at 10 or 4 o'clock - backer's choice)
- Stamped caseback with Irukandji artwork (brushed & polished)
- Regulated automatic Seiko NH35 movement
- 200m water resistance
SUCCESSFUL : Kickstarter: MAS Watch - Irukandji Dive Watch, Limited Color Run
Re: SUCCESSFUL : Kickstarter: MAS Watch - Irukandji Dive Watch, Limited Color Run
18 backers pledged AU$ 8,001 to help bring this project to life.
