SUCCESSFUL : Kickstarter: Heinrich Watches - Taucher Automatic Dive Watch
This is the first Kickstarter from Heinrich Watches out of Stuttgart, Germany for their debut model, the Taucher automatic dive watch.
And the campaign is already fully funded and all Super Early Bird slots have sold through.
Super Early Bird pricing was around $621 SOLD OUT
Early Bird pricing is around $644
Kickstarter pricing is around $674
Regular price will be about $869
Estimated delivery is May 2021
The Taucher is available in three colorways - black, green (Pantone 553 C), and blue (Pantone 286 XGC).
Changes From Prototype:
- Slight decrease of HEINRICH Logo on dial (see above) according to survey results from Sept 1, 2020
- Remove phantom date position of Sellita SW200-1
- No Quick Release bars. Not necessary due to the drilled lugs
- End links of the bracelet will be aligned with the case
- Blue dial color will change slightly from color tone Pantone Reflex Blue C to Pantone 286 XC (Medium dark shade of cyan-blue). Images are already reflecting new color tone
- Lume performance and bezel action will be improved
CASE
- Case diameter: 41 mm
- Lug-to-lug: 47.8 mm
- Height: 11.5mm, 13.6mm with chrystal
- Lug width: 20 mm
- Screw down crown
- Water resistance: 20 bar / 200m / 660ft
- Crystal: Double domed sapphire with anti-reflective coating
- 120-Clicks Unidirectional Sapphire Bezel
- Bracelet: Premium Stainless Steel Mesh bracelet with brushed links and Wetsuit Ratchet Buckle Diver Extension Clasp
MOVEMENT
- Swiss Made Automatic Sellita SW200-1
- 38-hour power reserve
- 26 jewels
- Vibrations Per Hour: 28,800
DIAL
- Sunburst dial in blue, green and black (other dial colors could be considered)
- Green: Dark pastel spring green. Color code: 100% Pantone 553 C
- Blue: Medium dark shade of cyan-blue. Color code: 100% Pantone 286 XGC
- Black
- Applied brushed indices filled with Swiss Super-LumiNova® BGW9
Re: SUCCESSFUL : Kickstarter: Heinrich Watches - Taucher Automatic Dive Watch
122 backers pledged €69,408 to help bring this project to life.
For those still interested in the Heinrich Taucher, you can still preorder direct.
https://www.heinrich.watch/shop
Preorder price is around $794
In addition, they've added two new colorways - burgundy or grey.
OR you can choose to have white markers instead of the vintage colored ones in all the colorways.
