UNSUCCESSFUL : Kickstarter: Forteller Watches - The Cambrian 300m Dive Watch *RELAUNCH*
Forteller watches from Norway have relaunched their Cambrian 300m Dive collection on Kickstarter.
Here's a link to their original unsuccessful campaign - viewtopic.php?f=25&t=2298
Kickstarter pricing is around $204
Regular price will be about $247
Estimated delivery is June 2022
The Cambrian is available in three colorways - black, blue, or white with a full lume dial.
- Movement: NH35
- Case: 316L stainless steel construction throughout
- Diameter: 39.3mm Case with 40.1mm Bezel
- Lug to Lug: 47mm
- Lug width: 20mm
- Thickness: 13.3mm (14.1mm including trilobite)
- Bracelet Dimensions: 20mm tapered to 16mm with 18mm signed clasp with milled mechanism
- Bracelet: Solid end links, solid links with 1.5mm screws
- Crown: Screw down
- Lugs: Drilled
- Caseback: Screw down with embossed and polished trilobite
- Bezel: 120 click unidirectional ceramic
- Crystal: Sapphire with 3 layers of AR coating (2.8mm thick)
- Lume: Swiss BGW9/C3 Superluminova
- Weight: 137g-167g on the bracelet or 98g on silicone or Horween leather strap
Re: UNSUCCESSFUL : Kickstarter: Forteller Watches - The Cambrian 300m Dive Watch *RELAUNCH*
UNSUCCESSFUL
The project's funding goal was not reached on Sat, December 18 2021 5:30 PM EST
Note from the creator:
After discussing with our factories we have managed to reduce the MOQ.
If all goes well production will start in January and we will open for pre-orders on our website.
Only pre-orders will then get the Horween leather and silicone straps included so look out on our website or follow our Instagram/newsletter to be informed when pre-orders are available.
Thanks for all the support on the campaign and stay tuned.
