What can you tell from how a watch ticks?
- Has thanked: 21586 times
- Been thanked: 12443 times
Some of my mechanical watches tick with a slight metallic clang, others do not. Some tick loudly, some softly. What do differences in the ticking sounds of mechanical watches tell about what is going on inside? Some can identify issues with a car engine just by listening. Is the same true for watches? Can listening for particular characteristics of a watch’s ticking sounds identify issues or a need for servicing?
- Sporkboy
- Has thanked: 2570 times
- Been thanked: 5989 times
Re: What can you tell from how a watch ticks?
Based on the experiences with Timex watch movements, you can tell something about the materials used based on the loudness of the ticking. Brass, plastic, stainless and aluminum will sound differently in loudness. This is inferred and extrapolated from what I have read and is not representative of independent research on my part.
- Split-Time
- Has thanked: 22315 times
- Been thanked: 10865 times
I will be interested to see were this conversation goes. My Timex Deep Space Snoopy ticks so loud that I can hear it across the room at night. The Timex Q is not nearly as loud. As for automatics, I have noticed that my new Glycine Airman No 1 is particularly loud and higher pitched (unscientifically) than any of my other autos (that I have noticed).
- DogOnTime
- Has thanked: 246 times
- Been thanked: 918 times
Majority is based on 2 things: case cavity and material.
If your automatic isn't particularly audible when it's left on a surface on a quiet night, more likely to have a plastic movement holder since it doesn't transduce the vibrations as easily... Or so I would think.
- Dub Rubb
- Has thanked: 24685 times
- Been thanked: 10738 times
Interesting topic. I would love to be able to diagnose problems with this method, and I am sure it's possible to the trained ear.
As far as my experience goes, all I know is if you can really hear a rotor free spinning, its probably a miyota. And if you can hear a mechanical ticking from across the room, its probably a Raketa.
