Yema Superman French Air Force 39mm Quartz Takes A Bath
After reading some unsavory reviews and rumors about Yema's quality control, particularly when it comes to water resistance, I decided to do my own test.
Superman French Airforce quartz in 39mm takes a half-hour bath.
Pleased to report no water intrusion that I could detect. No droplets inside the crystal, and no fogging.
Félicitations Yema!
Re: Yema Superman French Air Force 39mm Quartz Takes A Bath
Good, but that's hardly a test for a watch rated 660ft. A spit test would have worked just fine. [emoji3]
PetWatch wrote: Wed Oct 21, 2020 3:19 pm Good, but that's hardly a test for a watch rated 660ft. A spit test would have worked just fine. [emoji3]
Maybe I'll put it through the dishwasher next. 🤔 :lol:
ManOnTime wrote: Wed Oct 21, 2020 3:24 pm
Pressurize in the Instant Pot?
TheJohnP wrote: Wed Oct 21, 2020 3:31 pm
That may be something I'm willing to do with a less expensive watch.
Rabirnie
Post by Rabirnie »
Maybe I'll put it through the dishwasher next. [emoji848] :lol:
That would be a fascinating experiment. As [mention]ManOnTime[/mention] said though, only with an inexpensive piece.
So according to the Instant Pot website, the max pressure it cooks at is 15.23 psi: https://instantpot.com/which-electric-p ... 20(105kpa).
But that's like less than 1m of water depth based on what I'm seeing. Am I mixing up something?
Stretch44
Post by Stretch44 »
ManOnTime wrote: Wed Oct 21, 2020 4:20 pm
Someone please do this experiment.
cortman
Post by cortman »
Boourns wrote: Wed Oct 21, 2020 9:33 pm So according to the Instant Pot website, the max pressure it cooks at is 15.23 psi: https://instantpot.com/which-electric-p ... 20(105kpa).
A little- 1 psi = about 1.4 meters wc. So this is about 21 meters of water resistance. Still not much lol.
cortman wrote: Thu Oct 22, 2020 3:54 pm
In that case you should be able to cook a 50m timex in an instant pot no problem.
You have the figures mixed up, 1 meter of sea water exerts aprox. 1.4 psi, so 15.23 psi is about 10.5 meters depth.
It's the heat that may create a problem in the Instant Pot test, if not right away, long term.
By the way, the Yema jar test, giving it a generous 3 inch depth, exerted a tremendous 1.7 ounces per square inch. Good for a light shower, keep it out of puddles.
