I wish more companies would do the big moon, especially now that it appears Chris Ward no longer produces theirs. Like this white one, but maybe a bit too busy overall for me to add.TheJohnP wrote:Roger Zarzoso of Antoine Tavan 1805 has taken a break from posting conspiracy theories to share images of his upcoming enamel dial moonphase.
No idea on when these will launch or pricing, but gorgeous nonetheless.
Here's the original French copy, followed by the translation:
Antoine Tavan 1805, Grande Lune précision exact sur 3 ans, ensuite on avance 1 dent, soit 24 heures.
Email Grand Feu/cuivre. Montre 100% artisanale
Antoine Tavan 1805, Grand Moon precise accuracy over 3 years, then advance 1 tooth, or 24 hours.
Enamel Grand Fire/Copper. 100% artisan watch
2021 New and Upcoming Releases!
- cheddar
- Has thanked: 929 times
- Been thanked: 1131 times
Re: 2021 New and Upcoming Releases!
- tinpusher
- Has thanked: 724 times
- Been thanked: 772 times
I love everything about that watch except the star on the end of the hands. Just a bit too whimsical for what I think would go with the watch.
- MoT
- Site Admin
- Has thanked: 13423 times
- Been thanked: 30144 times
Nice looking watch, however his full throated embracing and promotion of said conspiracy theories will make me spend my dollars elsewhere.TheJohnP wrote: ↑Fri May 21, 2021 12:27 pm Roger Zarzoso of Antoine Tavan 1805 has taken a break from posting conspiracy theories to share images of his upcoming enamel dial moonphase.
- nicegator
- Has thanked: 13607 times
- Been thanked: 10418 times
New edition from Hemel. Awesome proportions and specs, wide choice of colors. Link for pre-order:
https://www.hemelwatches.com/products/the-sea-dart
- Boourns
- Has thanked: 4517 times
- Been thanked: 10272 times
So I wasn't a fan of the last colorful G Shock but I kind of love this one (except for the price). Available for pre-order now.
https://www.gshock.com/watches/limited- ... gb2000ph2a?
Bluetooth, multiband 6, etc. $1100The MTGB2000PH-2A is a special model based on the carbon MTGB2000, with a Blue Phoenix-themed design. . .
The bezel and the case have separate structures. The double rainbow IP finish of the bezel gives it a two-tone pattern with horizontal gradation, while the metal frame of the case has vertical gradation, which creates the image of a crossed line. The rainbow IP of this model creates distinctively unique color patterns for each watch. The multi-coloring of the face matches the colors of the bezel and case, while the navy blue semi-transparent band creates a further touch of elegance.
- Has thanked: 46865 times
- Been thanked: 35260 times
Boourns wrote: ↑Tue May 25, 2021 8:20 am So I wasn't a fan of the last colorful G Shock but I kind of love this one (except for the price). Available for pre-order now.
Does it come equipped with an amp and oversized subwoofers?
Or are those aftermarket?
- Boourns
If you don't already have them you aren't cool enough to buy this watch.TheJohnP wrote: ↑Tue May 25, 2021 8:34 amBoourns wrote: ↑Tue May 25, 2021 8:20 am So I wasn't a fan of the last colorful G Shock but I kind of love this one (except for the price). Available for pre-order now.
- MoT
- Site Admin
I would have been cool enough 25 years ago.Boourns wrote: ↑Tue May 25, 2021 9:01 amIf you don't already have them you aren't cool enough to buy this watch.TheJohnP wrote: ↑Tue May 25, 2021 8:34 amBoourns wrote: ↑Tue May 25, 2021 8:20 am So I wasn't a fan of the last colorful G Shock but I kind of love this one (except for the price). Available for pre-order now.
- pdsf
- Has thanked: 4335 times
- Been thanked: 3785 times
Zodiac vs W&W: https://windupwatchshop.com/products/zo ... ed-edition
Not sure how I feel about it yet.
Case: Brushed steel
Dial: Charcoal Gray
Movement: STP 3-13
Complication: Date
Winding: Automatic
Lens: Domed Sapphire
Strap: Two-Piece Fabric
Water Res.: 200M
Diameter: 40mm
Length: 49mm
Thickness: 13.6mm
Lug Width: 20mm
Limited: 182 Units
SKU: ZO9282
Warranty: Two Year Limited Warranty
Case: Brushed steel
Dial: Charcoal Gray
Movement: STP 3-13
Complication: Date
Winding: Automatic
Water Res.: 200M
Diameter: 40mm
Length: 49mm
Thickness: 13.6mm
Lug Width: 20mm
Limited: 182 Units
SKU: ZO9282
- Boourns
I'm a fan except for the strap. One step too far IMO.pdsf wrote: ↑Tue May 25, 2021 1:41 pm Zodiac vs W&W: https://windupwatchshop.com/products/zo ... ed-edition
Case: Brushed steel
Dial: Charcoal Gray
Movement: STP 3-13
Complication: Date
Winding: Automatic
Water Res.: 200M
Diameter: 40mm
Length: 49mm
Thickness: 13.6mm
Lug Width: 20mm
Limited: 182 Units
SKU: ZO9282
- pdsf
I initially read that as "one strap too far" lol I had to read again.Boourns wrote: ↑Tue May 25, 2021 2:04 pmI'm a fan except for the strap. One step too far IMO.pdsf wrote: ↑Tue May 25, 2021 1:41 pm Zodiac vs W&W: https://windupwatchshop.com/products/zo ... ed-edition
Case: Brushed steel
Dial: Charcoal Gray
Movement: STP 3-13
Complication: Date
Winding: Automatic
Water Res.: 200M
Diameter: 40mm
Length: 49mm
Thickness: 13.6mm
Lug Width: 20mm
Limited: 182 Units
SKU: ZO9282
I think I like it...the color pop of the date wheel is a nice touch.
- MoT
- Site Admin
Normally I like off-beat designs, but if there ever was a watch that was a try-hard, or doing too many things all at once, this is it.pdsf wrote: ↑Tue May 25, 2021 1:41 pm Zodiac vs W&W: https://windupwatchshop.com/products/zo ... ed-edition
Case: Brushed steel
Dial: Charcoal Gray
Movement: STP 3-13
Complication: Date
Winding: Automatic
Water Res.: 200M
Diameter: 40mm
Length: 49mm
Thickness: 13.6mm
Lug Width: 20mm
Limited: 182 Units
SKU: ZO9282
Maybe if I stare at it longer I can figure out what the heck they're attempting.
I stand by my stance of disliking external bezels, but that one is fun.
- pdsf
It's reportedly inspired by sneaker designs, which, to me at least, often suffer from "having too many things all at once"! I am a big fan of minimalist sneakers so when Common Projects first came onto the scene, I was quite pleasantly surprised. Now more brands are doing the same thing.ManOnTime wrote: ↑Tue May 25, 2021 2:14 pmNormally I like off-beat designs, but if there ever was a watch that was a try-hard, or doing too many things all at once, this is it.pdsf wrote: ↑Tue May 25, 2021 1:41 pm Zodiac vs W&W: https://windupwatchshop.com/products/zo ... ed-edition
Case: Brushed steel
Dial: Charcoal Gray
Movement: STP 3-13
Complication: Date
Winding: Automatic
Water Res.: 200M
Diameter: 40mm
Length: 49mm
Thickness: 13.6mm
Lug Width: 20mm
Limited: 182 Units
SKU: ZO9282
- Has thanked: 3778 times
- Been thanked: 3676 times
I see an increasing number of new releases incorporating colors and modern design cues that are more likely to appeal to a more youthful audience (when it comes to strapping a watch to your wrist youth is a condition of the mind) than your more typical staid WIS crowd. Whoops!
With consideration to personal preferences and tastes, it's great to see horology (design, tech, materials) evolving at a faster pace.
