Free watch to whomever can get this open
Re: Free watch to whomever can get this open
I have no real suggestions but I'm fully invested in seeing how this turns out.
Good luck!
Sent from my SM-G975U using Tapatalk
Good luck!
Insta me: bbrou33
Unfortunately the prongs are too large in diameter and they do not separate enough to fit around the caseback.
Seems you have another wrench, position wrench on caseback and tap wrench handle firmly in both directions, don't use too much force. Don't want to brake another wrench or damage caseback.
If penetrating oil, heat and cold which expands and contracts to brake rust doesn't loosen it, provided you are able to get enough grip and force, the cap threads or other caseback part may just snap and brake. I wouldn't apply force as a jolt anymore but gradually, though by the time you feel some give it will either be loosening or braking off.
PetWatch wrote: ↑Sat Apr 25, 2020 11:05 am Seems you have another wrench, position wrench on caseback and tap wrench handle firmly in both directions, don't use too much force. Don't want to brake another wrench or damage caseback.
I had 3 caseback wrenches, now two. Have never applied jolt force, only slow gradual. My issue now is how to hold the case in place against the force of the wrench as I do not gave a vice and wrenches with a pad to protect the case are proving very difficult
Have you tried a ball?
I ordered one and it arrived just today. i will be trying it next.
- Split-Time
With my luck step #1 would have tightened it up just a bit more . I'm not laughing at you. I am laughing with you!watchpalooza wrote: ↑Sat Apr 25, 2020 12:19 am Update: STILL not open. The caseback says it is stainless steel (while the case itself is clearly not) and the back is
1) Tried the opposite direction in case it would be reverse-threaded....no dice
2) Tried using a plumbing wrench to hold the case while using a case tool....nope
3) Heat did nothing except make me worry about damage
- AndroidIsAwesome
I'm a little late but what about getting some wax or rubber, melting it, then placing the caseback onto it, then let it harden into a mold if that makes sense
Same. Without sports for nearly two months this is like the Super Bowl. I generally root for the underdog so I'm definitely #TeamWatchpalooza.
When in doubt, C4.
All I know is that one day I am going to log in and see this
Or this (with increasing probability by the min).
LOL...it is really annoying that of my 300+ watches, this one is being a complete bitch. I have now a ball opener as suggested by [mention]TheJohnP[/mention], but no inflation needle to blow it up. Will try to get one tomorrow. Have to admit I am having thoughts of throwing this thing out the window or smashing with a hammer...
So strapping it to a speaker and letting that sucker rip doesn’t sound so crazy then[emoji6] if you do take a hammer to it, there needs to be a video, preferably high speed.watchpalooza wrote:LOL...it is really annoying that of my 300+ watches, this one is being a complete bitch. I have now a ball opener as suggested by [mention]TheJohnP[/mention], but no inflation needle to blow it up. Will try to get one tomorrow. Have to admit I am having thoughts of throwing this thing out the window or smashing with a hammer...
The ball didn't come inflated already?! Good thing mine did. Not sure I have a needle pump in this apartmentwatchpalooza wrote:LOL...it is really annoying that of my 300+ watches, this one is being a complete bitch. I have now a ball opener as suggested by [mention]TheJohnP[/mention], but no inflation needle to blow it up. Will try to get one tomorrow. Have to admit I am having thoughts of throwing this thing out the window or smashing with a hammer...
Insta me: bbrou33
Not to further deflate the ball idea, I have one, it flexes, no way you can get anywhere near the same torque from using a wrench.
