$35 Mechanical Field Watch Challenge
Re: $35 Mechanical Field Watch Challenge
I'm hoping to get lucky searching "watch needs battery" on ebay!
The Komandirskie came to my mind right away... maybe with no bezel? lol.peskydonut wrote: ↑Fri May 15, 2020 8:06 am Don't know if these would qualify (worth checking with @Sporkboy), but Russians are always a good source for cheap mechanicals.
EDIT: Just saw the rule for "no rotating bezel", that might disqualify most if not all Komandirskies.
If you pop off the bezel then the watch would not have a bezel. If you glue the bezel down then it wouldn’t have a rotating bezel.cortman wrote:The Komandirskie came to my mind right away... maybe with no bezel? lol.peskydonut wrote: ↑Fri May 15, 2020 8:06 am Don't know if these would qualify (worth checking with @Sporkboy), but Russians are always a good source for cheap mechanicals.
If Marlon Brando can remove the bezel from a Rolex GMT Master and have it pass for a field watch in Apacolypse Now, I figure it is OK to remove bezels from Vostoks to do the same.Sporkboy wrote:If you pop off the bezel then the watch would not have a bezel. If you glue the bezel down then it wouldn’t have a rotating bezel.cortman wrote:The Komandirskie came to my mind right away... maybe with no bezel? lol.peskydonut wrote: ↑Fri May 15, 2020 8:06 am Don't know if these would qualify (worth checking with @Sporkboy), but Russians are always a good source for cheap mechanicals.
The horrorSporkboy wrote: If Marlon Brando can remove the bezel from a Rolex GMT Master and have it pass for a field watch in Apacolypse Now, I figure it is OK to remove bezels from Vostoks to do the same.
Maybe there are some frankens from India that will fit the bill. Lots of Russian watches are out there that would work, many being sold as having been serviced. That isn’t a bad way to go if you find something that catches your eye.
I have seen some new watches that would work, but I would rather trust a used vintage movement of decent quality over a new piece of lower quality. Servicing is the big issue with these watches.
If you are handy with watches, you could theoretically find a decent lot and hope to get one working movement and enough compatible parts to build something.
Guyinwatch wrote: ↑Fri May 15, 2020 9:33 amThe horrorSporkboy wrote: If Marlon Brando can remove the bezel from a Rolex GMT Master and have it pass for a field watch in Apacolypse Now, I figure it is OK to remove bezels from Vostoks to do the same.
I am working on an image to use on Instagram to promote the challenge. Awaiting approval to use an image for this purpose.
If anyone wants to share the challenge, you can Use: viewtopic.php?f=35&t=1738
I tried using a URL shortener, but I couldn’t get that to work.
Not to give any pro tips away, but I think the first choice to make is whether you want to go for something “new” or something vintage. If new, then you are seeking an off-brand Chinese watch from Alibaba, ebay or amazon, or an atlas, timex or casio with the right style. There are countless "fashion" field watches which look the part, but would never be relied upon for actual field use.
If vintage, then its mostly about sniping auctions for either old trench watches between WWI and WWII, or watches from the 40’s or 50’s. You can also find options from the 60’s to 80’s, though there will be fewer options in the price range. There are specific brands to look for, but I’ll leave that to you to figure out. You will have to decide whether you want to buy something that functions vs “cobbling together” as Sporkboy has allowed in this contest. Personally I do not want to own too many Frankenwatches, so for me this choice is clear (one exception being an official “MoT” watch, of course). Hopefully that helps.
[mention]Sporkboy[/mention], one question re the rules:
Is the contest limited to wristwatches, or are pocket watches also an option?
From the article you linked
A watch was an invaluable tool to ensure military precision, but in the midst of battle, reaching into your pocket to check the time was impractical and potentially deadly. Wristwatches solved this problem.
Right...so there were both pocket and wrist field watches, and one came to be preferred over the other.Guyinwatch wrote: ↑Sat May 16, 2020 8:49 am
From the article you linkedA watch was an invaluable tool to ensure military precision, but in the midst of battle, reaching into your pocket to check the time was impractical and potentially deadly. Wristwatches solved this problem.
No. That is like saying the horseless carriage is a mid-size sedan. But i dig your style, and have said all along i am looking forward to the arguments as much as the watches. This is educational for me. And my opinion doesn't actually matter.watchpalooza wrote: ↑Sat May 16, 2020 8:57 amRight...so there were both pocket and wrist field watches, and one came to be preferred over the other.
It is natural that there is overlap in dial styles and features between pocket watches and field watches. I should make it clear that a field watch is wrist mounted.Guyinwatch wrote:No. That is like saying the horseless carriage is a mid-size sedan. But i dig your style, and have said all along i am looking forward to the arguments as much as the watches. This is educational for me. And my opinion doesn't actually matter.watchpalooza wrote: ↑Sat May 16, 2020 8:57 amRight...so there were both pocket and wrist field watches, and one came to be preferred over the other.
If you want to mount a pocket watch to your wrist, then by definition it is a wristwatch.
Pocket watches are only allowed if mounted to the wrist.
Fair enough.Sporkboy wrote: ↑Sat May 16, 2020 11:33 amIt is natural that there is overlap in dial styles and features between pocket watches and field watches. I should make it clear that a field watch is wrist mounted.Guyinwatch wrote:No. That is like saying the horseless carriage is a mid-size sedan. But i dig your style, and have said all along i am looking forward to the arguments as much as the watches. This is educational for me. And my opinion doesn't actually matter.watchpalooza wrote: ↑Sat May 16, 2020 8:57 amRight...so there were both pocket and wrist field watches, and one came to be preferred over the other.
