Random thing happened today. I have a Spinnaker Bradner, which powered by an NH35 movement.
It's always been a bit finicky since I got it, taking more effort/motion than usual to get it running and keeping a charge.
Today, I noted that it had stopped and, after giving it a shake, the second hand started running backwards.
On further experimentation, it runs forwards or backwards depending on which way up the watch is positioned.
I've not seen this before - any idea what would cause it and is it an easy fix?
Cheers,
B
Watch running backwards?
Re: Watch running backwards?
No idea but a simple fix is just replace the movement.
Probably more hassle than its worth for me. No idea where I would source a new movement in Dubai and imagine the cost of having it replaced here would almost meet the cost of the watch.
https://www.ebay.com/itm/1pcs-Small-Day ... Sw4IRfCYiR
Anyone who has modded a watch can swap out movements, this is just a 10 minute job for a watchmaker.
Thought I'd circle back on this with an update both frustrating and amusing.
I had some time this week, so figured I'd look at this watch again and see if it could be salvaged. First thing is to find out what the problem is. A spot of googling led me to the local(ish) authorised Seiko service centre, so off I go.
The conversation went something like this:
Baldrick: Hello, my watch isn't working properly and I'd like it serviced please. It's a Seiko NH35 movement.
Watch Tech: That's not a Seiko watch.
B: I know, but it's a Seiko movement- the NH35 - so I'm hoping you can look at it.
WT: [Looks at the exhibition back] This isn't a Seiko movement. It's the brand's own movement.
B: No, it's an NH35, they've just put their own rotor on it.
WT: NH35 isn't a Seiko movement.
B: Err...yes it is.
WT: No, Seiko movements are [reels off a list of other Seiko movements]
B: Yeees, but this is also a Seiko movement, a very common one. Look, here's about 59 websites confirming it is a Seiko movement.
WT: Ah, but that's just the Internet, it's often wrong.
B: O...kay? But in this case it's right. Look, it's basically a no-frills 4R35 or 36 movement.
WT: It's not a Seiko movement. I've never heard of this movement. You have to take it to the manufacturer or agent here.
B: That's you.
WT: ...
B: Look, you presumably have a database and a link to stock and parts from Japan, right? Go and check this movement.
WT: [5 minutes later ] It's a Seiko movement.
B: Yes, I know. So, you will service it, being the authorised SC and all...
WT: We'll look at it as a favour, but no guarantee and no warranty. Also, we won't test water resistance beyond 30 ATM [it's a dive watch]. Also it will cost you [obscene amount].
B: Fine.
Usually, I'd have walked away - it was a surreal conversation and I don't really have any faith in their competence. I can only hope that someone else actually does the work, as my options here are limited. The service price is also disproportionate to the value of the watch, but honestly I don't know where else I could get it fixed.
Let's see. I'm a bit peeved about the 30 ATM WR test, though. I'm going to assume - probably wrongly - that if it passes that test it will be fine for light water use / swimming etc. I won't use it diving anyway.
B: Err...yes it is.
B: That's you.
WT: ...
B: Fine.
baldrick wrote: ↑Mon Mar 15, 2021 5:56 am Thought I'd circle back on this with an update both frustrating and amusing.
B: Err...yes it is.
B: That's you.
WT: ...
B: Fine.
Did they mean 3ATM, 30m? 30ATM is 300m, so I think you'd be fine there.
As for the rest of that....I would have walked away.
3 ATM. I double-checked because it sounded wrong - especially as they presumably service Seiko divers. (Although, this guy obviously isn't exactly a reliable source of information....)
