SUCCESSFUL : Brand Direct: Maen Watches - Greenwich 38 Automatic GMT Collection
There are 150 pieces of the Greenwich 38 Automatic GMT available for direct purchase, but the remainder of the 150 are available for preorder at a slight discount. So that's what I'll be focused on.
Maen Watches has introduced their latest collection, the Greenwich 38 Automatic GMT.
https://www.maenwatches.com/pages/green ... omatic-gmt
Preorder price with VAT is €749 (roughly $881.15)
Preorder price without VAT is €599.20 (roughly $704.82)
Available price with VAT is €799 (roughly $939.84)
Available price without VAT is €639.20 (roughly $751.85)
Estimated delivery on preorder batch is November 2021
The Greenwich is the perfect travel watch with its GMT function and comfortable rubber Tropic strap. A custom integrated rubber strap is also available.
The dial offers very good legibility due to the oversized hour indicators.
At night, the watch is also a pleasure to look at due to the Swiss Super-LumiNova with superior Grade X1 quality.
The Greenwich has an elegant, but at the same time very powerful appearance.
The case design is based on our Hudson and is also 38mm in diameter.
There are some obvious differences though. First of all the Greenwich has a step up bezel with alternating brushed and polished effects.
The overall brushing is also more prominent. Next to that the crown is oversized and the case has lug holes.
With its 10 ATM water resistance and screw-down crown the Greenwich will feature as a great travel watch.
There are four colorways available - white (black dial, white GMT hand), orange (black dial, orange GMT hand), red (black dial, red indices), or blue (blue dial)
Model Case
- DIAMETER: 38mm
- THICKNESS: 12mm Including glass and caseback
- LUG TO LUG HEIGHT: 46mm
- WEIGHT: 62Gr
- CASEBACK: Solid screw-down
- CROWN: 7mm screw-down crown
- MATERIAL: 316L Surgical grade stainless steel
- BEZEL: Step up bezel
- CRYSTAL: Double domed sapphire crystal + AR coating
- WATER RESISTANCE: Waterproof to 10ATM
Movement
- MOVEMENT: SwissTech S24-045 Swiss Made Automatic Movement
- VIBRATIONS PER HOUR: 28,800 bph
- POWER RESERVE: ~40 hours
- COUNTRY OF MANUFACTURE: Switzerland, Swiss made
- JEWELS: 28 Jewels
- FUNCTIONS: Hours, Minutes, Sweep second, GMT hand and Date function
- WINDING: Self-winding mechanism with ball bearing
Strap
- STRAP: Rubber Tropic Strap
- STRAP WIDTH: 20mm narrowed down to 18mm
- CLASP: 316L Stainless Steel Buckle
Dial
- DIAL: Enamel
- LUME: X1 Superluminova
