SUCCESSFUL : Kickstarter: Eone - Switch, featuring Interchangeable Chapter Rings
Eone return to Kickstarter to launch their evolution of the Bradley, with the Switch.
The Eone Switch is a new, innovative timepiece that’s evolved from conversations with you, our community, and the belief that inclusion is not just about access, but also the freedom to choose. You choose how you tell time; use touch or sight. You choose your style; with interchangeable Rings.
Super Early Bird pricing is $295
Early Bird pricing is $310
Kickstarter pricing is $320
Regular price will be $360
Estimated delivery is February 2022
Our timepieces are designed to bridge a gap between accessibility and style, allowing people who are sighted, blind, or deaf-blind the same access to a functional, sleek, high-quality timepiece, unlike any other watch previously available.
The Eone Switch retains all the accessibility, quality and style of the original Eone timepieces, while incorporating these important new features and major improvements:
- Dial Changing Design with twist lock mechanism
- Improved case
- Enhanced ball bearing tracks
The Switch is available in Silver, Rose Gold, or Black.
Includes two Rings: Classic 12 hour and "Sunflower" guilloche
Included:
- One Eone Switch timepiece on a mesh bracelet (choose from silver, black, and rose gold).
- Two “rings”; one with original 12-hour markings and the other featuring the new, guilloche-inspired design.
- Additional ring price - USD $40 each
- Case and Strap material - 316L stainless steel
- Movement - Modified Ronda Quartz
- Case diameter (top and bottom) - 39mm and 41mm
- Case height (without dial) - 11.9mm
- Articulated lug-to-lug length - 50mm (30mm folded)
- Lug width - 20mm
- Water resistance - 3 ATM
Re: SUCCESSFUL : Kickstarter: Eone - Switch, featuring Interchangeable Chapter Rings
329 backers pledged $98,845 to help bring this project to life.
