2022 New and Upcoming Releases!
Let's do this.
Lovers of the Old Logo rejoice! Christopher Ward is releasing limited editions of a couple of old designs WITH THE ORIGINAL LOGOS!
C5 Malvern with old old logo, limited to 250 pieces, for $695:
C5 Specs:
Watch Model: C5
Dial Colour: White
Case Material: 316L Steel
Case Colour: Silver
Height: 11.6mm
Lug-to-Lug: 48.54mm
Water Resistance: 3 ATM (30m)
Movement: Sellita SW200-1
And the C8 Pilot with merely the old logo, limited to 200 pieces, for $695:
This one also comes in black case, which is limited to 50 pieces, for $815:
C8 specs:
Dial Colour: Black
Case Material: Stainless steel
Case Colour: Silver or Black
Height: 11.5mm
Lug-to-Lug: 53.2mm
Water Resistance: 5 ATM (50m)
All models here:
https://www.christopherward.com/int/spe ... %20Edition
C5 Specs:
Watch Model: C5
Dial Colour: White
Case Colour: Silver
Height: 11.6mm
Lug-to-Lug: 48.54mm
C8 specs:
Dial Colour: Black
Height: 11.5mm
Lug-to-Lug: 53.2mm
All models here:
Re: 2022 New and Upcoming Releases!
I actually like the old logos, but for the love of God Christopher Ward PLEASE STOP IT
Still one of my favourites and a lot cheaper on eBay!
- Landed_Alien
A new re-issue of the Swatch Jellyfish. I'm quite tempted to pick up one of these - just not sure which one would suit me. It's been a long time since I've worn swatches.
https://www.swatch.com/en-us/clear.html
Fratello article here: https://www.fratellowatches.com/swatch- ... dels-2022/
The thin one purports to be 3.9mm thick so I'd probably splurge for that one. Otherwise I'm a middle of the road 41mm guy. Still only 10mm thick and lug to lug 47mm.Landed_Alien wrote: ↑Fri Jan 07, 2022 4:56 pm A new re-issue of the Swatch Jellyfish. I'm quite tempted to pick up one of these - just not sure which one would suit me. It's been a long time since I've worn swatches.
- Landed_Alien
Yeah, the thin one had me interested. 37-39mm tends to be my sweet spot. 41 for a non-diver is large, but 34 is pretty small. Almost tempted to order the Gent, New Gent, and Skin, and return the two I like the least.
Also noticed, the Skin doesn't have a seconds hand, just a rotating gold disc. Not sure if that's a positive or not. It's not like it's a dress watch, but as a quartz I don't need to see anything tick.
Brew Watches will have three new colors of their Metric chronograph available this Friday at 10am ET. 200 of each color will be available. Green sunburst, blue sunburst, and navy
Pre-orders for the next batch of the Metric Retro will start at the same time. Expected delivery in May 2022.
CASE DIAMETER: 36MM x 41.5MM
CASE THICKNESS: 10.75MM
LUG WIDTH: 20MM
CRYSTAL: SAPPHIRE GLASS
CASE MATERIAL: STAINLESS STEEL 316L
CASEBACK: STAINLESS STEEL 316L
BAND: 20MM, STAINLESS STEEL, BRUSHED + POLISHED
BUCKLE:: FOLDING CLASP, MICRO-ADJUSTMENTS
WATER RESISTANCE: 5ATM (50 METERS)
MOVEMENT: HYBRID VK68 MECA-QUARTZ CHRONOGRAPH
All models retail for $395 USD. https://www.brew-watches.com/watches
LUG WIDTH: 20MM
Love this dial. Price - not so much.
Will try to get one on BF 2022.
https://www.undone.com/en/watch-detail/ ... -cali-blue
Oris X Cervo Volante (38mm) Big Crown Pointer Date (msrp $2000)
(pic from Forbes)
(pic from Forbes)
That matching tip on the date hand.
Re: 2021 New and Upcoming Releases!
The other models came out today. On the plus side they are a bit more subtle Popeye. https://vario.sg/collections/navi-x-pop ... -automaticTheJohnP wrote: ↑Sat Dec 11, 2021 1:29 pm Vario have released the first of their NAVI Jump Hour watches, with the rest of the collection available early in January.
My only concern is the can of spinach appears to be a small second hand, so the positioning is rather questionable.
Vario NAVI Jumping Hour Classic Popeye, Deep Water Blue
Price is $398
https://vario.sg/collections/navi-x-pop ... sic-popeye
Launching on 12 Dec 2021 SG Midnight (less than 100 pieces)
Due to the limited quantity produced, each order has a limit of 2 unit per person.
We are currently awaiting for the packaging to arrive so the watches may be dispatched towards end December. Delivery by end Jan if demand is high.
Specifications
- Case diameter: 38mm
- Case thickness: 11mm
- Crystal: flat sapphire crystal with magnifier inner AR applied
- Lug width: 20mm
- Lug to lug: 46mm
- Case Material: 316L stainless steel with solid caseback
- Movement: Seagull Jumping Hour movement ST1721, 21.6kpbh, more than 40 hours power reserve, Accuracy +-45s/day, Non hacking.
- Water resistance: 10 atm
- Strap: Single Pass Cordura with Zulu hardware (260mm)
- Warranty: 1 year global warranty
YK from @VesuviateWatches shared this on the League of Watch Microbrands group on Facebook, so reposting a teaser of their next collection, Viaggio.
Winfield Watches has launched a new collection of their Mission series.
These are all automatics, opposed to their previous quartz versions.
https://winfieldwatch.com/collections/mission-series
Winfield MD-1
Price is $565
Winfield MT Automatic Green
Price is $545
Winfield MT Automatic Blue
Price is $545
Shared Specs:
- Movement: NH35 Automatic
- Diameter: 41mm
- Lug to lug: 48.5mm
- Thickness: 13mm with domed crystal
- Lug width: 20mm
- Case: Heat treated 316L SS bead-blasted finish or Heat treated 316L black PVD bead-blasted finish
- Crown: Double gasket screw down
- Crystal: Double domed sapphire with double AR coating
- Bezel: Unidirectional (MD-1 only)
- Hands: Bead blasted stainless steel
- Lume: Extra heavy C3
- Water resistance: 200m / 660 feet
Winfield MD-1
Price is $565
Price is $545
Price is $545
Shared Specs:
- Diameter: 41mm
- Lug width: 20mm
HAPPY NOW??!?
Thanks for pointing that out.
