PREORDER: Brand Direct: Isotope Watches - HydriumX Exit Limited Edition
After the success of their sold out HydriumX Will Return model, Isotope is taking preorders for another version of the series, inspired by an exit sign.
The Isotope HydriumX® EXIT is limited to 100 pieces
https://isotopewatches.com/products/hydriumx-exit
Preorder price on white or grey FKM strap is £840 / roughly $842
Preorder price on black leather on green stitching is £880 / roughly $882
Estimated delivery is July 2023
Isotope® is launching another chapter of the HydriumX®, paying homage to that life-saving sign telling you where to exit. As it should, this watch is fitted with a full-lume dial that lights up when you need it the most. This not only makes the time easy to read but also reveals a little figure running for the door. As soon as you have made a safe exit and are back in the light, it escapes the dial. Lost for direction? Just follow the arrow-shaped second's hand to your nearest exit. It is another quirky yet fun detail that is an ode to the sign that is subconsciously part of our everyday life, no matter where you are on the globe.
For those of us in the US without the cultural reference, this is what their exit signs look like:
Specifications
- Swiss Landeron Mechanical Movement
- Micro-blasted case, 316L stainless steel
- Case diameter 40mm X 48mm (with lugs)
- Height 12.9mm (14.9mm with double domed Sapphire Crystal)
- Hydrium™ X screw-down exhibition case back
- Uni-directional bezel with 120 clicks
- Anti-reflective crystal sapphire
- Screw-down crown at 3 o’clock
- Off-white dial filled with Super-LumiNova® and bold Arabic numbers
- Isotope Lacrima hands with Super-LumiNova®
- Water-resistance 300m / 30 atm / 1000 ft
- 22mm Quick-release FKM strap (grey or white) or Italian Calf black leather w/ green with signed micro-blasted Steel Buckle
