Our friends at Viqueria (hello @Nickee) have launched their latest model on Kickstarter, the Levante MK3 mechanical chrono.
Though they've only had one successfully funded campaign out of their previous five, they do deliver on the watches they produce outside of the KS platform. In fact, I own two Viqueria watches.
Early Bird pricing for the regular edition of the Levante is around $309
Late Bird pricing is around $330
Regular price will be about $517
Early Bird pricing for the 50 piece limited Hinomaru edition is around $326
Estimated delivery is January 2024
NOTE- you can also preorder directly from Viqueria at - https://www.viqueriawatches.com/product ... te_racing/
The All-New Levante is the third version of our handwound chronograph and it's a completely different watch thanks to its upgraded specifications:
- Completely new case with new diamater and new design
- New movement with Swan Neck regulator
- Sapphire Crystal with AR Coating
- New dial design
The Levante is available in three regular colorways - Laguna Blue, Mugello Black and White Silverston
In addition, the Levante comes in a 50 piece limited variant, the Hinomaru Special Edition - White matte dial faded to red and with a red circle to honour the Japanese flag called Hinomaru and the famous Japanese Cherry blossom. The dial also features a special internal tachometer and Japanese characters.
- 41mm diameter
- 13.65mm thickness with crystal
- 20mm strap width
- Stainless Steel bezel insert
- Custom profile high-dome Sapphire crystal with AR Coating
- Exhibition case-back
- Seagull ST1901 column-wheel manual mechanical movement and Swan Neck regulator; Movement checked and regulated in our Italian workshop
- 21,600 bph with approx. 40 hours power reserve
- 30-minute Chronoscope function
- 10 ATM / 100mt water resistance
- O-ring crown construction
- Japanese Super-Luminova on bezel, index and hands
- Weight 167gr with bracelet
PREORDER: Viqueria Watches - Levante MK3 Mechanical Chronograph Collection
Re: PREORDER: Viqueria Watches - Levante MK3 Mechanical Chronograph Collection
I think these are really attractive.
